This is an internal error since the backup executes a function that is intended to be called on the primary. This will result in incorrect programming of hardware tables and internal data structure.
This is a severe internal condition needing technical assistance. Contact technical support with the following information: configuration, and the "show log" output.
Error
Function %func% should only be called on primary slot.
| Name | Type |
| func | String |
